How do I set up an eSIM?
Important: Some of these steps only work if your Fairphone has Android 13 or above. Learn how to Check and update your software version.
An eSIM is a digital SIM that allows your Fairphone to connect to your mobile network operator without having to use a physical SIM.
With an active SIM, you can make calls, send and receive SMS, and use mobile data.
- How do I get an eSIM?
- How do I download and set up an eSIM?
- How do I delete an eSIM?
- How do I use a Dual SIM?
If you have a Fairphone 4 or above, your phone has one eSIM slot. Ask your network operator if they support eSIMs, and if they work on Fairphone.
To request an eSIM, you may need the EID number. You can find it in two places:
- Printed on the box your Fairphone came in.
- On your Fairphone, go to:
Settings → About phone → SIM status (SIM slot 2) → EID.
When you start your Fairphone for the first time, follow the on-screen instructions to guide you through the process.
To activate your eSIM after you set up your Fairphone, contact your network operator to get a QR code. Then, follow these steps:
- Go to Settings → Network and Internet.
- Tap Mobile network.
- If you already have a SIM installed, tap on the + next to your SIMs.
- Tap Download a SIM instead.
- Tap Next.
- Scan the QR code (provided by your network operator).
- Tap Activate.
- Enter the Operator confirmation code of your eSIM (provided by your network operator).
- If required, enter your SIM PIN (your network operator should provide this) and your Screen lock (the PIN, pattern or password you use to unlock your phone).
- Tap Done.
You may need to delete your eSIM if you want to switch network operators or sell your phone.
To delete an eSIM, follow these steps:
- Tap on the SIM you want to delete.
- Tap Delete SIM.
All of our phones support Dual SIM functionality. With Dual SIM, you can use two SIM cards at the same time. Allowing you to:
- Have two phone numbers and two different plans on one device.
- Use one number for business and another number for personal calls.
Get a local SIM plan while traveling abroad.
To manage your Dual SIM preferences, follow these steps:
- Go to Settings → Network and Internet → Tap on one of your networks.
- Set your preference for each network:
- Data preference. Only one SIM can be the default for data.
- Calls preference. Pick a default SIM or tap Ask every time.
- SMS preference. Pick a default SIM or tap Ask every time.
Fairphone uses Dual SIM Dual Standby (DSDS) technology. You can read more about that here.
Trouble setting up an eSIM?
If your eSIM isn't working, you can often fix it in just a few simple steps. Find out how: Troubleshoot the SIM Card(s).
