Fairphone 2 cases
For the Fairphone 2, we offer slim case designs. They are an integral part of the phone. This means that when you order a Fairphone 2, this includes the case.
Order a separate case in our webshop if you want to change the look and feel of your device.
We made a video to show you how to open up the case and place it on your phone.
Slim case
All colors have a rigid black rim that surrounds the display of the phone. This design is protective and easy to remove. For use with outdoor lifestyles, we recommend to look for an additional rubberized and/or waterproof bumper or case. Or use a ziplock bag.
Dimensions (phone + case)
Length: 144.5 mm // Width: 74.5 mm // Thickness: 10.65 mm
Colors
- Coral red
- turquoise side keys
- color: Pantone warm red C (RGB 249 66 58) (Hex#F9423A)
- lettering: silver
- material: made of 50% post-consumer recycled polycarbonate (PC)
- Turquoise
- color: Pantone 632C (RGB 0, 147, 178) (Hex#0093b2)
- lettering: silver
- Indigo
- black side keys
- color: Pantone 2758C (RGB 0, 30, 98)(Hex#001e62)
- lettering: silver
- White
- black side keys
- lettering: silver
- material: made of 50% post-consumer recycled polycarbonate (PC).
FP2 - Regular cases
The regular cases with an integrated rubber rim, are sold out. We do not produce these anymore.
The regular cases versions were: black matte, blue matte, transparent and black translucent.
The rigid material of the back is polycarbonate (PC). The flexible rim of the regular back cover consists of thermopolyurethane (TPU).
Dimensions regular case (phone + case)
Length: 143 mm // Width: 73 mm // Thickness: 11 mm.
FP2 - Transparent regular cases
The transparent and black translucent cases are not available. We found out they break too easy. We are currently researching improvements.
FP1 - 3D printed cases
The 3D printed back cases are NOT designed for the dimensions of the Fairphone 2. The 3D printed back covers are designed for the dimensions of the Fairphone 1 and Fairphone 1U.
