Extend the battery life of your Fairphone
You want to use all the possibilities of your smartphone, but the energy lifespan of your battery is limited. Certain functions, like display brightness and data connections, drain your battery in no time. Efficient energy use helps you push those limits and extend the amount of time between charges.
Use the tips listed below to get more out of each battery charge. Not only with your Fairphone 2, but with any smartphone.
If all this does not improve your battery behavior, make sure to check if your battery has not reached the end of its life and you need to replace it.
1. General
As with any smartphone, the Fairphone 2 works on a lithium-ion battery. So let us start with some general recommendations to get the most out of it.
1.1 - Battery Saver
To quickly enforce diminished battery use:
- Swipe down with two fingers from the top of the screen to open the pull-down Quick settings menu and tap on the Battery icon
- Toggle the grey switch in the right corner - below the graph - to the right to turn the connection off. The switch should turn blue.
1.2 - Battery graph
You can see yourself which functions use the most energy in your phone. The graph shows the pace of energy consumption. Below the graph, the functions are listed in order of most to lesser use. Tap the graph to get a more detailed graph and list.
Certain tasks, such as Android OS, Android System, and Google Services are the core of the operating system. As they are essential, you can not directly optimize their battery consumption.
However, you can monitor your downloaded third-party apps that have the most impact on your battery.
- To adjust their settings: open the app and navigate to either menu or settings.
When you first start using your Fairphone, you may see drops in the battery report graph. No need for concern: your battery needs to complete a few charging cycles before it calibrates properly.
To go quickly to the battery graph:
1.3 -SIM card
Make sure your SIM card is new and undamaged. An old (+1 year) or damaged SIM card makes your phones' processor work harder to keep up and can even cause serious issues.
1.4 - Temperature
Batteries need an optimum temperature to keep the chemical processes inside going. So avoid extreme heat and cold. Do not put your phone in the bright sun and keep it inside a pocket when outdoors in below zero temperatures.
2. Adjust your brightness
Your screen requires a lot of energy when in use, especially with a large, 5-inch screen. Adjust the brightness to reduce the amount of energy.
Dim the brightness level of your screen:
- Slide the little sun icon to the left to dim your display. For the Fairphone 1: touch the sun icon to switch between different brightness settings.
Access advanced brightness and sleep settings under Settings → Display.
- Turn on Adaptive brightness (Fairphone 1: Automatic brightness). This automatically adjusts the brightness on your screen to the ambient light.
- Tap Sleep to adjust the time period for your phone to go into sleep mode. To save energy, pick a short time period like 30 seconds.
3. Adjust your connectivity settings
Data connections usually consume the most energy - apart from the display. If you use cellular data or Wi-Fi non-stop, you can drain a fully-charged battery in just a few hours. In general, it’s best to disable the connectivity functions that you do not need.
3.1 - Quick
To quickly turn them off or back on again:
- Tap the desired icon: Wi-Fi, Bluetooth or Cellular data.
- Toggle the blue switch in the top right corner to the left to turn the connection off. The switch should turn grey.
3.2 - Advanced
Access advanced connectivity settings via Settings.
To set your data use preferences for each SIM card:
- Go to Settings → Data usage to set your data use preferences for each SIM card
To let the device decide which cellular network to use based on the signal strength:
- Go to Settings → More → Cellular networks to select a SIM card. Pick 4G as the Preferred network type.
3.3 - Airplane mode
The best way to conserve energy without completely turning off your phone, is Airplane mode. If you can survive for a while without any data or network connections, use this.
- Swipe down with two fingers from the top of the screen to open the pull-down Quick settings menu and tap on the Airplane icon.
3.4 - Extra
If you have a weak mobile or Wi-Fi signal, your phone will consume more energy to stay connected.
- Move closer to the access point or turn off the data connection if you’re not using it
- Renew your SIM card when it is older than a year or damaged
- If you spend lots of time online, you may want to install an ad blocker to reduce the amount of bandwidth and energy required to load a page.
4. Change your location settings
Location settings can also impact your battery usage. We recommend to switch to a less accurate, but more battery-friendly location setting when possible.
Before you can make any changes, you need to enable Google Location Services and accept the license. To do this:
- Go to Settings → Location → Google Location History.
It’s important to realize that this mode reduces accuracy, so do not use this if you need very specific location information, such as directions while you are driving. You can learn more about location settings on this Google Help page.
- Go to Settings → Location → Mode and select Battery saving.
If you do not require any location services at all:
- Swipe down with two fingers from the top of the screen to open the pull-down Quick settings menu and tap the Location icon.
5. Decrease the workload of your phone
Certain apps, accounts, and features impact your battery life as well. A few ways to decrease your phone’s workload include:
Wallpapers: Choose a static image instead of a dynamic one. To select a new wallpaper:
- Touch and hold a blank space on your home screen, and then tap Wallpapers at the bottom left.
Inactive apps: Uninstall apps you do not use.
- Go to All Apps, hold down the app you want to remove and slide it to Uninstall at the top of the screen and release your finger.
Accounts: You can remove online accounts that you do not use.
- Go to Settings → Accounts. Locate the account you want to remove. Use the Settings menu (three vertical dots) to remove the account.
Users: Remove unnecessary users. The Guest account cannot be removed.
- Go to Settings → Users. Tap on the cog wheel icon next to the user profile that you want to remove. Tap Remove user.
Touch vibration (haptic feedback): Turn off touch vibration.
- Go to Settings → Sound & notification >→ Other sounds. Disable Vibrate on touch.
Keyboard vibration: Turn off keyboard vibration.
- Go to Settings → Language & input → Android Keyboard → Preferences and turn off Vibrate on keypress.
