Fairphone 2 Dual SIM feature
The compatible SIM card for Fairphone 2
The Fairphone 2 only supports a micro SIM card (3FF)(ID-000 format), sized: 15mm x 12mm x 0.76mm.
If you have a nano-SIM card, please:
  • avoid using a SIM adaptor in your FP2 (it may increase the risk of damaging the SIM connectors)
  • do not use a SIM card which was cut in an electronics store (or at home) to the size of a Mini SIM - always ask your provider for a new SIM-card.
Dual SIM Feature
With a Fairphone 2, you can use two SIM cards from different service providers and even from different countries. You can make and receive calls and text messages from both cards, but mobile data is available only from the preferred SIM card.
When your provider is a mobile virtual operator the SIM card works only in 3G or 4G. Because it is not possible to use 4G in both SIM cards at the same time, you  must use SIM2 as a hotspot and make sure to change the SIM1 into 2G. It is not possible to deactivate the SIM cards.
Configure your preferences
When you add or change the SIM cards (one or both), a configuration notification will appear. Touch it to go to:
  1. SIM card settings - or go to the general Settings menu of the phone
  2. SIM cards → SIM Enablers*
  3. Choose to enable/disable a SIM card
  4. Name each of your SIM cards
  5. Go to Preferred SIM
  6. Set your preferences for Mobile data, Calls, SMS messages.
NOTE: *The toggle to disable one of the two SIM cards is currently not available with the latest Android 7 update. This is a known issue and it is tracked in our public bug tracker.
Want to know more about the bug tracker? Check this support article
If you want to use this option, you need to downgrade your phone to Android 6. Please, keep in mind that you have to perform a factory reset. We recommend waiting for Android 7 updates, to resolve the issue.
Toggle and limit mobile data connection
To toggle mobile data connection for each SIM card:
  1. Go to Settings
  2. Data usage
  3. Toggle mobile data
To limit mobile data connection for each SIM card:
  1. Tap the date range to select the day of each month when you want the mobile data counter to be reset (for instance when your data plan is renewed)
  2. Toggle on the Set mobile data limit setting
  3. Use the orange ruler to set your limit.
The phone will notify you and deactivate mobile data on that SIM card when the threshold is reached (per cycle).
Furthermore, you can define a mobile data warning: your phone will notify you once you've used a certain amount of mobile data through that SIM card.
Last but not least, you can restrict the mobile data used in the background. This means that apps will not be synchronizing any data (e.g. receive e-mails and Internet calls, refresh the weather forecast, etc.) until you use them. This will reduce the amount of mobile data used.
  1. Tap the More settings icon (the three vertical dots at the top right corner)
  2. Select Restrict background data
Set the preferred network type (2G/3G/4G)
There can be only one SIM card connected to a high-speed network type (3G/4G). To define which one:
  1. Go to Settings > More > Mobile networks
  2. Define, per SIM card, which network type you would like to use
  3. Switch a SIM card to a high-speed network type (4G (preferred)/3G/2G or 3G (preferred)/2G), by making sure that the other SIM card is set to operate on 2G only
Toggle mobile data roaming (when you are abroad)
Remember to double check your configuration if you are going abroad. Using mobile data while you are abroad can be expensive, better be safe than sorry!
  1. Go to Settings
  2. More
  3. Mobile networks
  4. Cellular network settings
  5. Data roaming
  6. Tick the checkbox if you want to use the mobile data while traveling
  7. Repeat the step above for the second SIM card
Final tips
Using mobile connection may be expensive and can drain your battery faster than usual.
To quickly enable or disable mobile data on your preferred cellular data SIM card use the Quick Settings pull-down menu:
  1. Swipe down from the top of your screen
  2. Tap on the mobile connection symbol
  3. Use the Cellular data switch, on the top right corner.
If you have a weak mobile signal, your phone will consume more energy to stay connected. When this happens, try to move closer to the access point or turn off the data connection if you’re not using it.
