How to connect your Fairphone 1 to a computer
This article explains how to connect your Fairphone 1 to a PC, Apple MacBook and Linux computer running Fairphone OS version 1.6 or higher.
If you use an older version of Fairphone OS on your Fairphone 1, please update it to the latest version.
Once your computer recognizes your Fairphone 1 as a USB storage device, you will be able to transfer files (e.g. music, pictures, contact lists, videos).
How to connect your Fairphone 1 to a Windows PC
- Connect your Fairphone 1 with a USB data cable to the PC.
- It should automatically connect and show up under My Computer.
- If it doesn’t connect automatically, open the notification panel on your Fairphone 1.
- Select USB connection and then select MTP mode.
NOTE: if the "USB connection" notification doesn't appear on your phone, the FP1 is not detecting the connection. This is most likely caused by a faulty USB port (either on the computer or the phone) or a faulty cable. Please try different combinations.
How to connect your Fairphone 1 to a Mac
Before you are able to connect your Fairphone 1 to an Apple Mac, you must install the Android File Transfer first. You can use this application to view/transfer files between your Apple Mac and the Fairphone 1.
After the installation is done, connect your Fairphone 1 via a USB data cable. Android File Transfer will open and show you the content of the device.
If it doesn’t connect automatically:
- Open the notification panel on your Fairphone 1.
- Select USB connection.
- Select MTP mode.
Applications and services like iCal, iTunes and iCloud will not work on the Fairphone 1 because they are made specifically for Apple devices.
How to connect your Fairphone to a Linux machine
Connecting your Fairphone 1 to a Linux computer is slightly more difficult than connecting it to a PC or Apple Mac device. It should work without any issues. Read here and here on how to use your Fairphone 1 in combination with a Linux computer. Also, an easy solution is to install the mtpfs package. Read more about mtpfs.
