How to connect your Fairphone 1 to a computer
This article explains how to connect your Fairphone 1 to a PC, Apple Mac and Linux computer running Fairphone OS version 1.6 or higher. If you use an older version of Fairphone OS on your Fairphone 1, please update it to the latest version.
In most cases extra software is not required to connect your Fairphone 1 to a computer. The device will immediately be recognized. Once your computer recognizes your Fairphone 1 as an USB storage device, you can transfer files (e.g. music, pictures, contact lists, videos).
How to connect your Fairphone to a PC:
  1. Connect your Fairphone 1 with an USB data cable to the PC
  2. It should automatically connect and show up under My Computer
  3. If it doesn’t connect automatically, open the notification panel on your Fairphone 1
  4. Select USB connection and in there select MTP mode.
How to connect your Fairphone 1 to an Apple Mac:
Before you are able to connect your Fairphone 1 to an Apple Mac, you must install the Android File Transfer software first. You can use this application to view/transfer files between your Apple Mac and the Fairphone 1.
After the installation is done, connect your Fairphone 1 via a USB data cable. The device will show up in a Finder window.
If it doesn’t connect automatically:
  1. Open the notification panel on your Fairphone 1
  2. Select USB connection
  3. Select MTP mode.
Please note
Applications and services like iCal, iTunes and iCloud will not work on the Fairphone 1 because they are made specifically for Apple devices.
How to connect your Fairphone 1 to a Linux computer:
Connecting your Fairphone 1 to a Linux computer is slightly more difficult than connecting it to a PC or Apple Mac device. It should work without any issues. Read here and here on how to use your Fairphone 1 in combination with a Linux computer. Also, an easy solution is to install the mtpfs package. Read more about mtpfs.
Was this article helpful?
9 out of 73 found this helpful
Have more questions? Submit a request
Can't find what you're looking for?
Ask the community
Visit forum
