“Peace of Mind” widget
"Peace of Mind" is one of the four pre-installed widgets that comes with the Fairphone 1 OS.
This widget lets you disconnect from the world and enjoy a bit of silence. When the Peace of Mind function is active, you won’t receive phone calls, messages, e-mails or status updates. But you can still access content offline.
The Peace of Mind widget is on your Home panel. Tap on the widget to enter the app and slide the bar up to determine how long you’d like to be left alone.
Enjoy it!
