How to insert and format a MicroSD card on Fairphone 1
- Open the back of your phone and remove the battery. You’ll see the MicroSD slot to the right of the SIM cards. You can use MicroSD cards of up to 64GB (with any of the formats available in the market: SD / SDHC or SDXC)
- After you insert the MicroSD card, put the battery back in and put the back cover back on
- Press the Power button to start your phone.
Some users have reported problems reading microSD Cards (Type SDXC) of 64 GB capacity.
There are some SDXC type cards that come in a certain format called exFAT. This is a proprietary format as you can read in the wikipedia source.
Fairphone does not support this format, but there is an easy way to solve that. You can reformat your SD Card to a format called FAT32. There are multiple sources online to help you out with this. Here is one.
It is also advisable to re-format your SD card directly from your phone:
- Go to System Settings
- Choose Storage
- Tap "Erase SD card"
- Tap "Erase everything".
For FP2
For FP3
