Check what software version you have installed
The latest software update available for the Fairphone 1 is Kola Nut 1.8.7 (released in August 2015). You can update your Fairphone 1 through the built-in Fairphone Updater app:
  1. Go to ‘All Apps' from the Quick Access (Edge Swipe) side menu
  2. Open the ‘Fairphone Updater’ app
To update to Kola Nut 1.8.7 press the button ‘Install new version’. Make sure you are connected to a Wi-Fi network and that the battery is charged. If you encounter issues with updating, check our support article on troubleshooting the update process
Software update Kola Nut 1.8.7 addresses the following:
  • German and Danish roaming fixes
  • Fix for multi-touch issue on Mozilla reported by ralf-xda
  • Security fixes: CVE-2015-3864, CVE-2015-1538, CVE-2015-1539, CVE-2015-3832, CVE-2015-3824, CVE-2015-3827 and CVE-2015-3829 (collectively referred to as the Stagefright bug)
  • Other security fixes: CVE-2015-0973 and CVE-2015-3636
Was this article helpful?
9 out of 22 found this helpful
Have more questions? Submit a request
Can't find what you're looking for?
Ask the community
Visit forum
