How to add and configure an app or widget to my home panels
Apps
  • Add apps to the Home panels using the All Apps and Widgets function (six dots in a circle). Hold down the selected app and drag it to the panel of your choice
  • To rearrange the layout of apps, press the icon and drag them to a different panel or location within a panel. You can also make folders - a collection of apps- by dragging and dropping apps on to one another. After doing this, tap the collection to name it.
  • To delete apps, press the icon with your finger and drag it to the top of the screen until the word "Delete" turns red.
Widgets
  • Add widgets to the Home panels using the All Apps and Widgets function (six dots in a circle). Hold down the selected widget and drag it to the panel of your choice.
  • Widgets can be used either as full panels or as parts of these panels. To resize, press and hold using the circles on the edge of the widget. You can rearrange the layout of widgets by pressing them and dragging them to a different panel or location within a panel.
  • To remove a widget from your home panel: hold the widget down with your finger and drag it to the top of the screen until the word "Delete" turns red.
Was this article helpful?
4 out of 26 found this helpful
Have more questions? Submit a request
