Android 14: Frequently asked questions (FAQ)
How do I get Android 14 on my Fairphone?
Android 14 is available for the Fairphone 5. To get Android 14, check and update your software version.
What changes will I notice with Android 14?
Learn more about the changes introduced with Android 14 in our blog post: Android 14 is here.
Why should I update to the latest software version?
We always recommend updating to the latest software version. In addition to new features that enhance your experience, each new software version contains important security and privacy-focused improvements.
I haven't received the Android 14 update. What now?
It can take a few days for Android 14 to become available to everyone. If you haven't received the update yet, please check again in a few days.
There was an issue while preparing to restart. What now?
If you receive this message while trying to update your Fairphone, wait at least a few hours, then try the update again.
Why is it no longer possible to turn on always-on display?
Our data shows the Fairphone 5's always-on display feature was a major source of battery drain. After much consideration, we decided to remove this feature so that your Fairphone will last even longer on a single charge.
I don't like dark theme. How do I turn it off?
Easy! Go to Settings → Display → Dark theme and tap to turn on or off.
Will Android 14 come to the Fairphone 4?
If you're using a Fairphone 4, we haven't forgotten you. Unfortunately, we will not be able to roll out the Android 14 update for Fairphone 4 users just yet. There are some issues we have run into for which we will need Qualcomm's support on.
This is taking a little longer than we anticipated. As it stands, we do not see the update rolling through in 2024. Hopefully, we should know more in early 2025.
We will continue to provide security patch updates on Android 13.
Will Android 14 come to the Fairphone 3?
After extensive research, we have made the difficult decision not to upgrade the Fairphone 3(+) to Android 14. The legacy Linux kernel (4.9) used in the Fairphone 3(+) poses significant challenges for the upgrade. It currently offers limited support for Android 13, and would not support Android 14 at all. For more details about Fairphone 3(+) Software support and security visit our Fairphone 3(+) FAQ.
Please note that we are closed on 18th April 2025 due to a public holiday in the Netherlands.
Due to a high volume of requests, we have limited our chat opening hours to assist as many customers as possible. If you have an open request, please know we are working hard to get back to you as quickly as we can. Thank you for your patience.
