How do I change my ringtone?
You can change your ringtone by going to:
  1. System Settings Audio Profiles
  2. "Pre-defined profiles": under "General," press the icon to the right: Settings.
  3. Under "Incoming Calls," choose "Voice call ringtone." Here you can set your default voice call ringtone.
In the pop-up window, you can listen to each ringtone until you find your favourite.
To add your own music file as a ringtone, connect your Fairphone to a computer, and put the music file you want to use in the "Ringtone" folder on the phone.
Was this article helpful?
219 out of 545 found this helpful
Have more questions? Submit a request
