Enhance the sound quality on the Fairphone 1
If you listen to music on your Fairphone 1, you want the best experience there is.
If you find the standard sound quality too bland, there is an easy fix to improve this.
  1. Go to Settings Audio profiles
  2. Select “BesAudEnh”.
From now on you will experience your music with a much more dynamic sound.
Was this article helpful?
2 out of 8 found this helpful
Have more questions? Submit a request
