How to close apps running in the background on my Fairphone 1
Each app that you open, you have to close by hand too. If you do this, it will keep your Fairphone 1 running smooth and it saves battery life.
It is very easy to do!
  1. Tap the Home button on your Fairphone. This is the middle button at the bottom of your touchscreen
  2. You will see all opened apps in separate windows
  3. Swipe the opened apps on your screen to the left or right
Need more help? Contact our support team!
