Where can I find my Fairphone 1 unique identifiers?
You can find your Fairphone 1 serial number and IMEI numbers underneath the battery.
The battery's serial number is on its bottom side.
To find them
- Turn off your phone
- Remove the metal back of your phone
- Pull out the battery
NOTE: You can also find your Fairphone serial number on the bottom side of the box in which it was shipped.
