What are the technical specifications of the Fairphone 2?
The Fairphone 2 offers advanced functionality and uses higher-end components, including these technical specifications:
OS
- Android 7.1.2 Nougat
Processors
- Snapdragon 801, Qualcomm MSM8974AB-AB
- Quad-Core 2.26 GHz Qualcomm
GPU
- Qualcomm Adreno 330 GPU 578 MHz, 2 GB LPDDR3
RAM
- 2 GB LPDDR3
Flash Storage
- 32 GB eMMC5
SAR rating
- SAR10g: 0.65 W/kg (Head); SAR10g: 1.1 W/kg (Body)
Networks
- Configuration: Dual-SIM, Dual-Standby (DSDS)
- Network Technology: 2G / 3G / 4G LTE-Advanced
- GSM/GPRS/EDGE: Quad-band: 850, 900, 1800, 1900 MHz
- WCDMA: Bands 1 (2100 MHz), 2 (1900 MHz), 8 (900 MHz)
Connectivity
- WLAN: IEEE 802.11 b/g/n/ac, 2.4 GHz and 5 GHz
- Bluetooth: 4.0 LE and earlier
- GPS / GNSS: GPS, A-GPS, Glonass
- FM Radio
Display
- Display Size: 5 inch Full HD, 1080 × 1920, Pixel Density 446 ppi
- Cover Glass: Gorilla Glass 3 (0.7 mm thick)
- Display Type: LCD TFT/IPS
Main Camera
- 12MP CMOS Sensor with dual flash: Omnivision OV12870 - Back Side Illuminated
- Image sensor size: 1/2.8 inch, Pixel Size: 1.25μm x 1.25μm
- F-number: f/2.2
- Video speed: 30 fps
Front Camera
- 5MP CMOS Sensor: Omnivision OV5670
- Image sensor size: 1/5 inch, Pixel Size 1.12μm x 1.12μm
- F-number: f/2.4
Audio
- Speaker: Built-in, Rear-facing
- Headset Jack: 3.5 mm
Interface and Connectors
- USB Port: Micro-B 2.0 with OTG support
- MicroSD Support: SDHC, SDXC, UHS
- Expansion Port: Backside - connectivity to external case, USB 2.0 Device Interface + Power Input
- Sensors
- Ambient Light, Proximity, 3-axis Compass, 3D Accelerometer, 3D Gyroscope
Battery and Power
- Removable Battery Pack: 2420 mAh at 3.8V (9.2 Wh), Lithium-Ion
Dimensions and Weight Slim case phone
- Length: 144.5 mm
- Width: 74.5 mm
- Thickness: 10.6 mm (back of case to top of glass)
- Weight: 148 g (phone) + 16 g (external case)
- The Fairphone 2 has two SIM ports that each can fit micro SIM card (3FF)(ID-000 format), sized: 15mm x 12mm x 0.76mm.
For more details, please check out the specifications page. Scroll all the way down.
Energy use
We designed the software for the Fairphone 2 to optimize energy use. However, the energy consumption of your smartphone depends on the way you use it. The piece of hardware that uses the most energy is the back-lit LED screen. Apps also account for a significant amount of energy use and some are more efficient than others.
A single battery charge will last:
- Standby (idle): up to 240 hours
- Calling on LTE (4G) (screen off): 16 hours
- Video streaming on LTE (4G): up to 4 hours
Plastic
Not all the plastic parts in your Fairphone 2 are marked to identify the material. This is something we will improve in new production cycles.
The rundown of the plastics we use:
- 50% post-consumer recycled polycarbonate - the best option available:
- the opaque back covers (coral red, turquoise, indigo, white)
- the rims of the slim back covers
- the plastic used on the modules
- the plastic used on the back of the screen
- regular polycarbonate - there is no alternative for transparent plastic that meets our quality needs:
- the transparent and translucent black back covers
- thermo polyurethane:
- the flexible rim of the regular back covers
Packaging
The design of the packaging unifies product box and shipping box. The result is a much smaller box made of Paperfoam: an innovative, eco-friendly material. It is compostable and uses much less energy in production than regular cardboard or paper pulp.
