How to delete app preferences
Sometimes, you might need to delete your app preferences, especially if some apps or functionality is not behaving as you expected.
To delete your app preferences
  1. Open the pull-down menu using two fingers and tap on the settings icon (cogwheel)
  2. Scroll down and tap on "Apps"
  3. Next, tap the three vertical dots on the top right corner and tap "Reset app preferences", then “Reset apps”.
Was this article helpful?
13 out of 33 found this helpful
Have more questions? Submit a request
