Where to find the unique identifiers (serial numbers) of the Fairphone 2 modules?
Introduction
Every Fairphone 2 module is identified by a UID (unique identifier) composed of a combination of letters and numbers. These unique identifiers allow us to track the modules down to the day they have been manufactured.
If you get in touch with us, we might ask you to provide the unique identifier of one or more modules.
Note that the following letters are not used: 'i', 'o', 'u', and 'y'. This prevents the reader to misread the digits '0' and '1'.
If you need it, we have a guide with instructions on how to open the Fairphone 2 and get to the modules.
For Fairphone 3/Fairphone 3 +, see the FP3 identifier page.
Full phone or Core Module
The unique identifier of your FP2, and more specifically of the Core Module, is the IMEI1.
You can find the IMEI1
- on the phone itself (see below) or
- on the original white foam shipping box or
- on your invoice.
Working phone
The quickest way to find the IMEI1 of a working phone is the following:
- Go to Settings → About phone → Status → IMEI information
- Slot 1 states the IMEI1
- Slot 2 states the IMEI2
Non-working phone
If the display stays black or the phone doesn't work anymore, you can look inside the phone instead. The IMEI1 is located on the side of the Core Module, below the volume buttons. It is composed of 15 digits (there are no letters), e.g. 1234567890123456.
Display Module
The unique identifier of the Display Module is located on the back of the module, between the two blue clips. It is composed of 10 characters (letters and digits) and starts with an A, e.g. Axxxxxxxxx.
Depending on the version of the display you have, the manufacturing day of the frame might be engraved on the top of the back side, e.g. Made on 18.12.2015.
Top Module
The unique identifier of the Top Module is located on the underside, close to the front camera. It is composed of 10 characters (letters and digits) and starts with a B, e.g. Bxxxxxxxxx.
Camera Module
The unique identifier of the Camera Module is located on the top, above the camera sensor. It is composed of 10 characters (letters and digits) and starts with a C, e.g. Cxxxxxxxxx.
Bottom Module
The unique identifier of the Bottom Module is located on the back, on the bottom under the screw holes. It is composed of 10 characters (letters and digits) and starts with a D, e.g. Dxxxxxxxxx.
Battery
The unique identifier of the Battery is located on its back. It is composed of 14 characters (letters and digits) and starts with a F, e.g. Fxxxxxxxxxxxxx.
