How to mute your Fairphone 2 (without vibration)
Whether you’re hard at work or taking a well-deserved break, you might want to mute your phone to eliminate distractions.
To mute your phone and turn off the vibration function, simply hold the volume button down until you feel a slight vibration. Tap "None" and then you see this on your screen:
TopTips-Mute2
This is the last vibration you’ll experience if you stay in “silent mode”. When you put your phone on mute, it will be set to “no interruptions” (not even alarms!) for an indefinite amount of time by default. If you’d like a more customized experience, you can mute your phone for a specific amount of time, or instruct it to only alert you about priority notifications or alarms.
Was this article helpful?
43 out of 122 found this helpful
Have more questions? Submit a request
