How to take a screenshot (FP2)
Whether you’re searching for something online or using an app, it’s often handy to take a screenshot – especially if you want to access information later when there’s no Wi-Fi in sight.
To take a screenshot, hold your phone with both hands, and press and hold the volume down button and power button at the same time until you hear a little “ping”. Immediately after you take the screenshot, it will appear in the notifications bar.
All screenshots are automatically saved to Photos (under All Apps). If you don’t see them immediately, tap on the options at the top left corner of the Photos app and then select “Device folders”.
TopTips-Take-Screenshot
Was this article helpful?
472 out of 558 found this helpful
Have more questions? Submit a request
