How to receive and read MMS (APN settings) on my Fairphone 2 (draft)
If you don't have cellular data (4G/3G) or you can't receive MMS messages, it usually means your APN (Access Point Names) settings are wrong, or they are not there at all.
Please check if there are APN settings defined for the SIM card which has to connect to the Internet:
  • Settings > More > Mobile networks > Access point names. You should find the current settings for your provider/phone operator.
  • If there are multiple choices or no choice at all, please get the correct APN settings from your provider's website.
