Fairphone 2 OS Downloads
Introduction
If an automatic update does not work, you can install an update manually. Download one of these most recent versions of the Fairphone OS for the Fairphone 2 to do this. These files are sorted by Android version.
To use any of the files listed:
or
  • Refer to the README file included in each .zip archive.
Need information for Fairphone Open? Go to code.fairphone.com.
When you want to update your phone to the latest version of Fairphone OS, try the built-in Fairphone Updater app first.
Downgrade
If you want to downgrade to the earlier version of Android than the one you currently use, a Factory reset is necessary. This means you need to make a backup.
Please note
We only maintain the most recent version of Fairphone OS. If you downgrade, we can not offer you support with any bug you might encounter.
-IMPORTANT-
The Android upgrade cannot install on encrypted devices with secure start-up enabled.
Disable secure start-up first:
  1. Go to the security settings.
  2. Re-enter your current screen lock, but leave secure start-up disabled. You can re-enable it after you are done installing the update.
The files
We only list the last updates of each version, as they have the most recent security patches and fixes for that version.
Android 10
Android 10 files:
Android 9
Android 9 files:
Android 7.1
Android 7.1 files:
Android 6.0
Android 5.1
Please note that we are closed on 18th April 2025 due to a public holiday in the Netherlands.
Due to a high volume of requests, we have limited our chat opening hours to assist as many customers as possible. If you have an open request, please know we are working hard to get back to you as quickly as we can. Thank you for your patience.
