How to connect your Fairphone 2 to a computer
General
To connect your phone to a computer, you need a data USB cable. Not all charging cables transfer data too.
When you connect your Fairphone 2 to your computer - it should immediately recognize your phone. In most cases, you do not need additional software. Once your computer recognizes your phone as a USB storage device, you can then transfer files to it (such as music, pictures, contact lists, videos).
If your phone is not visible:
- Connect your Fairphone with a USB data cable to your PC
- Pull down the notification bar on your phone
- Tap the notification from Android System (USB charging this device) to open the USB usage menu
- Select File Transfers (MTP) or choose Photo Transfer (PTP) if MTP is not supported.
If you don't see a notification, make sure you use a data transfer cable (opposed to a charging cable).
Microsoft/Windows
To connect your Fairphone to your Windows PC:
- Slide the notification bar down on your Fairphone
- Choose USB for charging
- In the menu, choose File transfer. If you do not select File transfer on the phone, the device will be still recognized by your computer but will appear empty.
- The Fairphone should show up as a device under My Computer in your PC.
Some Android devices are not recognized by Windows 7 because of missing drivers. The solution: you can install universal drivers. One example is the ADB Driver.
If you cannot find your Fairphone on your computer, check the Devices and Printers. You might find it there. If this is not the case, try to connect your phone to a different computer. If the other computer also does not list your phone, your bottom module might be broken.
Apple/Mac
To connect your Fairphone to your Apple Mac:
- Download and install the Android File Transfer driver on your Mac device. Android File Transfer is an application for Macintosh computers (running Mac OS X 10.5 or later) to view and transfer files between your Mac and an Android device
- Connect your Fairphone to your Mac device with a data USB cable
- Slide the notification bar down on your Fairphone.
- The File Transfer app will now pop up on your Mac device
- Transfer your files!
Important
Applications and services like iCal, iTunes and iCloud will not work on the Fairphone because they are made specifically for Apple iOS.
LINUX
To connect your Fairphone to your Linux computer:
To connect your Fairphone to a computer using older version of Linux is a bit complicated but it is possible and should work without any problems. Read the articles here, on how to use your Fairphone with a Linux computer. Another easy solution is to install the package mtpfs. Read more here about mtpfs.
Newer versions of Linux are usually able to communicate with your Fairphone device right away, you might have to turn on the parameter "USB Debugging" on your device; you will find it in the Settings under the section Developer option which you must have enabled in advance (instructions on how to enable Developer option are not published on our website and might be found online).
After you will just have to pull down the notification bar on your phone, tap on Android System notification (USB charging this device) to open the USB usage menu and select File Transfers (MTP).
