Understanding Adaptive Brightness
Adaptive Brightness is a feature on your mobile phone that automatically adjusts the screen's brightness based on the ambient light conditions. The goal is to provide optimal visibility while conserving battery life.
How it works
Your phone uses sensors to detect the surrounding light levels. Based on this information, it adjusts the screen brightness accordingly. When you move from a dark environment to a bright one, the screen brightens to remain visible. Conversely, it dims in low-light conditions to reduce eye strain and save power.
Learning your preferences
Adaptive Brightness also learns from your manual adjustments. When you manually change the brightness, the system records the ambient light level and your preferred brightness setting. Over time, it uses this information to fine-tune its automatic adjustments, better matching your preferences.
Troubleshooting tips
  • Give it time: The learning process takes several adjustments, so be patient as the system adapts to your preferences.
  • Reset if needed: If you're not happy with how Adaptive Brightness is working, you can reset it by turning it off and then back on. This clears the system's memory of your past preferences and allows it to start learning again.
  • Manual override: Remember, you can always manually adjust the brightness if needed, even with Adaptive Brightness enabled.
-IMPORTANT-
In some cases, the automatic adjustments may not be perfect, especially after sudden changes in lighting. This is because the system needs some time to "learn" the new environment and your preferred brightness level.
Please note that we are closed on 18th April 2025 due to a public holiday in the Netherlands.
Due to a high volume of requests, we have limited our chat opening hours to assist as many customers as possible. If you have an open request, please know we are working hard to get back to you as quickly as we can. Thank you for your patience.
