Forward calls on your Fairphone 2
Often, it is possible to forward calls on your phone. If this is available to you, depends on the options of your provider and call plan.
When your provider and plan enable forwarding calls, follow these steps:
  1. Open the Phone app
  2. Tap the Menu icon on top left (three grey dots vertically aligned)
  3. Select Settings
  4. Select Calling accounts
  5. Tap the intended SIM card icon or the name of the provider
  6. Select All calling accounts
  7. Select Call forwarding
  8. Select Voice
  9. Select your preferences
Done!
