How do I forward calls on my Fairphone 2?
It depends on the options of your provider and call plan if it is possible to forward calls.
When your provider and plan enable forwarding calls, you can follow these steps to forward your calls:
  1. Open the phone app
  2. Tap the Settings icon on top left (three grey squares on top of each other)
  3. Select Calling accounts
  4. Tap the intended SIMcard icon or the name of the provider
  5. Select Call forwarding
  6. Select Voice
  7. Select your preferences
Done!
Was this article helpful?
1 out of 3 found this helpful
Have more questions? Submit a request
