Fairphone 2: IMEI & Serial Numbers of the Phone and its Modules
Every Fairphone 2 module is identified by a UID (unique identifier) composed of a combination of letters and numbers. These unique identifiers allow us to track the modules down to the day they have been manufactured.
If you get in touch with us, we might ask you to provide the unique identifier of one or more modules.
Note that the following letters are not used: 'i', 'o', 'u', and 'y'. This prevents the reader to misread the digits '0' and '1'.
If you need it, we have a guide with instructions on how to open the Fairphone 2 and get to the modules.
For Fairphone 3(+), see the Fairphone 3(+) identifier page.
Full phone or Core Module
The unique identifier of your Fairphone 2, and more specifically of the Core Module, is the IMEI1.
You can find the IMEI1:
- On the phone itself (see below).
- On the original white foam shipping box.
- On your invoice.
Working phone
The quickest way to find the IMEI1 of a working phone is the following:
- Go to Settings → System → About phone.
- Scroll down and check IMEI (sim slot 1).
Non-working phone
If the display stays black or the phone doesn't work anymore, you can look inside the phone instead. The IMEI1 is located on the side of the Core Module, below the volume buttons. It is composed of 15 digits (there are no letters), e.g. 1234567890123456.
Display Module
The unique identifier of the Display Module is located on the back of the module, between the two blue clips. It is composed of 10 characters (letters and digits) and starts with an A, e.g. Axxxxxxxxx.
Depending on the version of the display you have, the manufacturing day of the frame might be engraved on the top of the back side, e.g. Made on 18.12.2015.
Top Module
The unique identifier of the Top Module is located on the underside, close to the front camera. It is composed of 10 characters (letters and digits) and starts with a B, e.g. Bxxxxxxxxx.
Camera Module
The unique identifier of the Camera Module is located on the top, above the camera sensor. It is composed of 10 characters (letters and digits) and starts with a C, e.g. Cxxxxxxxxx.
Bottom Module
The unique identifier of the Bottom Module is located on the back, on the bottom under the screw holes. It is composed of 10 characters (letters and digits) and starts with a D, e.g. Dxxxxxxxxx.
Battery
The unique identifier of the Battery is located on its back. It is composed of 14 characters (letters and digits) and starts with a F, e.g. Fxxxxxxxxxxxxx.
Identify v1 and v2 camera modules
You can identify which modules you currently have installed in your Fairphone 2 directly on the device:
- Update the phone to the latest version of the OS.
- Go to Settings → About phone.
- See Top module info and Camera module-info.
The upgraded modules identify as:
- Front camera 5MP - OmniVision OV5670
- Main camera 12MP - OmniVision OV12870
The first version of the modules identified as:
- Front camera 2MP - OmniVision OV2685
- Main camera 8MP - OmniVision OV8865
Physical differences
You can also identify the modules by looking at them. They can be distinguished once you know what to look for.
The Camera Module
Search for a white horizontal plastic edge separating the flash from the camera lens. If you see it, you have an upgraded camera module.
The Top Module
The top module is a bit trickier to identify. You have to check the connector socket. To do this, you have to take out the module first. If you have never removed a module from your phone before, check our article about replacing modules.
Once you have the module in your hands, check for the presence of the brown gasket on the connector socket.
Now, you should know which version of the module(s) you have.
