FP2. Forward calls
Often, it is possible to forward calls on your phone. If this is available to you, depends on the options of your provider and call plan.
When your provider and plan enable forwarding calls, follow these steps:
  1. Open the Phone app.
  2. Tap the More options icon (3 vertical dots) in the top right corner.
  3. Select Settings.
  4. Select Calling accounts.
  5. Tap the intended SIM card icon or the name of the provider.
  6. Select Call forwarding.
  7. Select the setting you wish to change.
  8. Input the number where you wish to forward the call (including the country code).
  9. Tap on UPDATE.
Done!
