Fairphone 2 (A9). Add your ringtone
If you like to hear your favorite song every time someone calls you, you can set an audio file as the ringtone of your Fairphone 2.
To get that unique ringtone there are two methods: a quick one and a version with more steps.
Quick method
To quickly add a ringtone:
  1. Get the song or recording on your device:
    1. Download the song using your phone
    2. Record a sound recording
    3. Share the file via Bluetooth
  2. Add the file as a ringtone:
    1. Swipe up the All apps bar on your Home screen
    2. Tap the Settings icon
    3. Scroll down to Sound and tap it
    4. Tap Phone ringtone
    5. Scroll all the way down to find + Add ringtone and tap it
    6. The file manager opens. On the top left, tap the Hamburger button (three horizontal lines )
    7. Tap through the folders to where your file is. Depending on how you captured the audio file, this can be Downloads, Bluetooth, Audio, or the internal storage of your phone:  FP2.
      1. If the file manager does not show FP2, in the menu on the top right, again tap on the three vertically aligned dots to Show internal storage. Now try again.
    8. When you find it, tap the file
    9. You are now back in the Ringtone menu. Select the audio file that should now show up in the list. It will play once
    10. Press OK at the bottom to confirm your selection.
When someone calls you, you should now hear your favorite sound!
Method with an audio file in place
This method takes more steps, but you can place the audio file deliberately in a place of your choice. In this instruction, you place the audio file in the internal storage of your phone.
  2. Place the file in the right place:
    2. Tap the Files icon
    3. Search in Downloads, Bluetooth, or Audio to find the audio file
    4. Press and hold the file until it is selected: the top bar shows 1 selected
    5. On the top right, tap on the three vertically aligned dots to select either Copy to... or Move to...
    6. Tap on the hamburger menu (three horizontal bars) on the top left to Copy to... and select FP2. This is the internal storage of your phone
      1. If it does not show FP2, in the menu on the top right, again tap on the three vertically aligned dots to Show internal storage. Now try again.
    7. Select Ringtones
    8. Push the blue button Copy at the bottom
  3. Select the file as your ringtone:
    3. Scroll all the way down to Sound and tap it
    5. Select the audio file that should now show up in the list of ringtones. It will play once.
    6. Press OK at the bottom to confirm your selection.
