FP2. Set your ringtone
To change the ringtone:
- Go to the Settings icon
- Scroll down to Sound and tap it
- Tap Phone ringtone
- Select a ringtone of your liking. Tap on it to listen to it, it will play once
- Press OK at the bottom to confirm your selection.
You have successfully changed the ringtone!
If you want, you can also scroll all the way done to add a ringtone of your choice.
