FP2. Coverage outside of Europe
Europe
Fairphone 2 is optimized for European cellular and 4G/LTE networks, so it’s not guaranteed to work everywhere in the world.
Fairphone 2 used to have global coverage (everywhere, all the time, anytime) thanks to its 2G support.
Also for 3G and 4G, you would have got at least one band supported anywhere in the world.
Lately (2020) 5G gained increasing commercial popularity, thus network providers started switching some resources towards 5G signal. This will still not be an issue anywhere in Europe, because Fairphone 2 supports a lot of different bands, but it might cause some issues if traveling around the world.
When traveling outside of Europe you will have to check in advance which network bands are still supported.
Rest of the world
How well the phone works outside of Europe depends on local networks as well as the operator you use.
If Fairphone 2 seems not to be supported, you might try to check a different network company (support might vary depending on the company).
Some providers restrict international SIM card use - especially on pre-paid plans. Check with your provider what the terms and conditions are for international use.
US
When it comes to the United States, 4G(LTE) won’t work.
You will have to check if some provider still supports other network interfaces like 2G and 3G. Without this, you will only be able to rely on Wi-Fi.
Special cases
Colombia, Ecuador, Turkey, Chile & others
It is not possible to register the Fairphone 4 in countries that require the so-called homologar procedure. For example, the phone is not registered in the USA and thus doesn't have the required FCC registration code that would allow usage. The procedure exists to prevent anonymous use of mobile devices. It's used mostly in the North and South American markets.
Registration is mandatory in some countries. This means that you can not use the device with a SIM card after the period has ended that each country has set (usually 1 month). You can still use the device with WiFi or Bluetooth connection.
Network specifications
- Configuration Dual-SIM, Dual-Standby (DSDS)
- SIM Sockets 2 x Micro-SIM (3FF)
- Network Technology 2G / 3G / 4G LTE -Advanced
- GSM/GPRS/EDGE Quad-band: 850, 900, 1800, 1900 MHz
- WCDMA Band 1 (2100 MHz); Band 2 (1900 MHz); Band 8 (900 MHz)
- 3G Max Downlink Speed Cat. 24 - 42.2 Mbps
- 3G Max Uplink Speed Cat. 7 - 11.5 Mbps
- 4G / LTE Advanced Band 3 (1800 MHz); Band 7 (2600 MHz); Band 20 (800 MHz)
- 4G Max Downlink Speed Cat. 4 - 150 Mbps
- 4G Max Uplink Speed Cat. 4 - 50 Mbps
If you have any further questions on how a Fairphone 2 will perform outside of Europe reach out to the provider you'll use and show them the network specifications.
