FP2. Report bugs or issues
It may happen that you encounter a potential software bug. In that case, you can use our public bug tracker for Android 9 or Android 10 on Fairphone 2 to help us solve the issue.
Via our public bug tracker you can:
- Check the list of reported issues.
- Add your issue - like new or upvote a similar issue.
- Provide extra information and details.
- Share your experience directly with our developers.
- Get direct updates on your issue.
Please consult the bug tracker landing page for further instructions on how to use it, or to go directly to the bug tracker.
In case your issue is not mentioned in the bug tracker and/or you need more information or data to submit your issue, please use our troubleshooting tool.
If you have more questions or need our help, please contact our Customer Support.
