Charge your FP3
The Fairphone 3 does NOT ship with a charger or a headset included in the package. You need a USB Type-C charger and/or cable to replenish your FP3 battery. You can order a compatible Fairphone 3 USB-C charger in our webshop. The cable of this charging equipment also allows data transfer.
If you have trouble charging, try at least with 3 different but compatible chargers (see the specifications below).
Find a charger for your Fairphone 3
The reason that we do not ship the phone default with a charger is that we do not want to create unnecessary electronic waste. As most people already have the right USB Type-C charger or cable at home, a default charger might be redundant in your situation. Consult the specifications list below to see if your charging equipment is compatible.
When you do not have the right charger at home, ask family or friends if they have a spare charger or USB-C cable that is compatible. Make sure the cables and chargers you use match the technical specifications listed below: then it should be good to go!
You can order a compatible Fairphone 3 USB-C charger and USB-C data-cable in our webshop. If you opt for another brand, we recommend to visit our forum to discuss experiences, compatible brands/products and tips with other community members.
USB-C and Quick Charge
The Fairphone 3 uses USB-C charging as it is the new industry standard. It supports features like quick charging and a reversible connection.
Quick charge
The FP3 supports Quick Charge. This means you can supply your battery with new energy quicker than before using a Quick Charge compliant USB Type-C cable. For quick charging, you will need charging equipment that enables this. See the specifications mentioned below.
USB-C
The port and plug have no dedicated direction in USB-C. This way we avoid damage to the charger or the USB port of your phone as there is no 'wrong' direction anymore.
Specifications
A charger and cable for the Fairphone 3 must have the following specifications:
  • 5 volts (5V)
  • minimum output of 1 Ampère/h (1A, 1000mA) - beware that this will have a slow charge
  • maximum output of 3 Ampère/h (3A, 3000mA)
  • Qualcomm Quick Charge processor compatible, version QC 3.0
  • the cable must have one USB-C connector
  • manufactured by a USB certified brand (if your product has no brand or the brand name does not show in this list, it is NOT certified)
  • must be compatible with a Qualcomm chip, version 3.0 (not all Quick chargers are compatible) See also this list of Qualcomm compatible charging equipment (.PDF alert).
The first time you charge your phone, please use a charger that delivers at least 1 Ampere (1A, 1000mAh) and allow more than an hour for your battery to show a charge.
When you experience problems with charging:
  1. Make sure your charger is compatible. Supercharge USB-C cables are not compatible with FP3. An example is Huawei's USB type C cable. We invite you to visit the community forum to exchange tips and recommendations.
  2. Try at least 3 different chargers and USB cables
  3. Consult our Troubleshooter
  4. See if you find solutions on our forum
  5. Contact us if these previous steps do not solve the issue
[USB-A to USB-C cable]
[FP3 Charger plug with USB-A port]
Please note
  • The charging times will vary greatly according to the charger used.
  • It is possible to charge the Fairphone with only 0.5 amperes (0.5A, 500mA) and 5 volts (5V), but it might be not enough when your battery is completely empty.
    In case you tried several different chargers and cables and still have issues with charging, please contact our support team!
