Change your ringtone
To change the ringtone:
  1. Swipe up the All apps bar on your Home screen
  2. Tap the Settings icon
  3. Scroll down to Sound and tap it
  4. Tap Phone ringtone
  5. Scroll down to find a ringtone of your liking. Tap it to listen to it, it will play once
  6. Press OK at the bottom to confirm your selection.
You have successfully changed the ringtone of your Fairphone 3!
If you want, you can also add a ringtone of your choice.
