Android introduction
Your Fairphone 3 runs on a Fairphone operating system (OS), which is based on the Android operating system, version Android 9 Pie. An operating system allows you to operate a computer or smartphone for example.
In case you are a beginning Android user, it can be quite helpful to consult:
Switching from another operating system to Android? We advise you to consult the following tutorials on this topic to help you out!
Need more help than you can find in the mentioned resources? Our customer support can help you out!
