FP3(+). Take a screenshot
With the Fairphone 3/Fairphone 3+ (FP3/FP3+), there are two ways to make a screenshot. You can choose the new, quick feature or opt for the method you might remember from previous Android versions where you do not have to touch the screen.
Your screenshots are saved on the internal memory of the phone and are accessible in three ways.
Make a screenshot
Quick method
To quickly make a screenshot:
- Press and hold the Power button
- Three options show: Power Off, Restart, and Screenshot
- Tap Screenshot to make the screenshot
- A sound notification - unless your phone is silenced - and a screen flash confirms that you successfully made the screenshot!
Classic method
To make a screenshot without tapping the screen:
- Hold your phone with both hands
- Press and hold the Volume down button and Power button at the same time
- Press until you hear a sound notification - unless your phone is silenced - and the screen flashes.
- Congratulations, you just took a screenshot!
Access your screenshots
Your screenshots are accessible in three ways. Via the Notification bar, via your File manager, or via the Google Photos app.
Notification bar
Right after you made the screenshot, the quickest way to access the screenshot is via the notification bar.
- Swipe down from the very top of your screen. The Notification panel will open
- You can now view, share, edit or delete the screenshot
File manager
You can always access your screenshots via your File Manager, even when the notification disappears from the top bar. To go to your screenshot with the File manager:
- Access all apps swiping on your screen from bottom to top
- Look for and tap on the Files app
- Tap the Hamburger button (three horizontal bars) in the top left corner
- Tap Images
- Tap Screenshots
- Select the screenshot you want to view, share, edit, move, copy, or delete.
Photos app
You can always access your screenshots via the Google Photos app, even when the notification disappears from the top bar. To go to your screenshot with the Photos App:
- Look for and tap on the Photos app
- Tap on the Hamburger button (three horizontal bars) in the top left corner
- Select Device folders
- Select Screenshots
