Headphones, headsets or external speakers for the FP3/FP3+
There are different standards for the 4-pins of a headset with mic (and remote). Here you can find the explanation about the different types and with a simple measurement you can check what wired* headset you have:
The Fairphone 3/Fairphone 3+ (FP3/FP3+) use the standard 3,5 mm AHJ=CTIA (ground=2).
We do not have the capacity to test headphones and we are not in the position to endorse the use of any brands or types of headphones.
However, we invite you to visit our awesome community via the forum to make a nice list of good headphones that you and others have tried out.
If you are looking for information about Bluetooth headphones, headsets, or external speakers consult the article Setup and troubleshoot a Bluetooth connection
Your device does not work
If your device does not work on your P3/FP3+:
- Make sure your device is compatible with the FP3/FP3+ and, in general, Android devices. Headsets made for Apple devices might not work.
- If the sound is still not working, please check that your head jack is not damaged. Try at least 3 different headphones to deduct if it is really the head jack of the FP3/FP3+ that causes the problem and not a broken headphone.
If your issue persists, use the Troubleshooter tool or contact our customer support
