FP3(+). Install Fairphone OS offline
To update your Fairphone 3(+) (FP3(+)), always use the regular procedure.
If you encounter an issue, you can follow this article to perform a manual update installation of Fairphone OS on FP3(+) using a computer.
This article will also help you to revert to Fairphone OS if you installed a different Operative System (OS).
Preliminary steps
- Before you start with any procedure, make a backup of your data. If you do not, you might lose your files like photos, music, contacts, etc.
- Unlock the bootloader of your FP3(+). Those instructions cover Fairphone OS. If you have installed a different OS on your Fairphone, the instructions might be slightly different. In this case, you will have to look for the instructions yourself.
- Download onto your computer (pay attention to Android version):
- Fairphone OS (Android 11) -
File name: FP3-REL-8901.4.A.0013.4-gms-c1b5afb7-user-fastbootimage.zip
md5sum: 945896193a4e48e767e6d734dc861ccb
sha256sum: 7d9643a6b1fdedcc52b30f59634e75a3d5eb4389d297f530e318d0d87006f891 - If possible, check your current build number to ensure equal to or lower than the Fairphone OS provided here.
Read this article to know how to check your version.
If your Fairphone OS version is higher than the one provided, you might lose all data. To boot your device, you might have to wipe the user data partition. To avoid it, make a backup of your data.
Instructions apply to the Chrome Browser. You can use any browser, but some steps will be different.
Requirements:
- Access to a computer
- USB-C certified data cable
- Your Fairphone 3(+)
Instructions
- Complete the preliminary steps above!
- Charge your Fairphone above 80%.
- Turn off your FP3(+).
- Boot your device into Fastboot mode.
Press and hold the volume down button followed by the power button (up to five seconds).
The device will display "Fast Boot Mode" for two seconds, then it will show the following screen: - Check that the red line at the bottom states the message:
DEVICE STATE - Unlocked - You can now release all the buttons.
Depending on which computer you are using, you will have to follow a different procedure. To proceed, select below which computer you are using.
- Windows 10 (recommended)
- macOS X 10.1x +
- Linux Ubuntu-based 18.x +
If after reading the article you need more help, get in touch with our Customer Support.
