FP3(+). Apps misbehaving
Sometimes one or more apps, or their related functions, will not work as intended.
Update your phone
The first step would be to Update your FP3(+) to the latest software.
Update your apps
Open your Play Store → tap on the Hamburger button (three horizontal lines ≡ in the top right corner) → My apps & games → Update all.
Start your app again and check if it works now.
Clear cache
Each app has a cache that hosts temporary data files for quick access. Sometimes those data become corrupted causing issues in your phone. To solve this, you can clear the cache of these apps
This will not erase user data (e.g. settings, pictures).
For the specific app:
- Go to Settings → Apps & notifications.
- Tap on "SEE ALL xxx APPS".
- Find the app and tap on it.
- Tap on Storage & cache.
- Push the button CLEAR CACHE.
If this didn't solve your issue you should continue to the next step.
Clear storage
Each app stores also the settings and preferences on your phone. If an app that use to work suddenly stops it might be useful to reset it to its default settings.
- IMPORTANT -
Before proceeding, you might want to make a backup because by resetting the app, you will lose your personal data contained within the app. Depending on the app those might just be your preferences (like login and/or a password), but also some files or photos (think of you WhatsApp pictures).
- Push the button CLEAR STORAGE.
If after reading the article you need more help, get in touch with our Customer Support.
