Android 10 introduction
Fairphone 3/Fairphone 3+ (FP3/FP3+) will run by default Fairphone OS (Operating System), which is based on a (light) customization of the operating system Android 10
An operating system allows you to operate a computer or smartphone for example
In case you are a beginner Android user, it can be quite helpful to consult:
- Our tutorials on the FP3/FP3+
- The Android Help center
- Our community-driven forum.
Switching from another operating system to Android? We advise you to consult the following tutorials on this topic to help you out!
- Our tutorial on migrating from iOS to Android
- The Google Android tutorials on migrating from iOS to Android
Need more help than you can find in the mentioned resources? Our customer support can help you out!
