Fairphone 3(+) OS Manual Installation with Ubuntu
First, complete all the steps from the article Fairphone 3(+) OS manual installation.
Ubuntu/Ubuntu-based (kernel 18.04.x and newer) process
- Connect the Fairphone 3 (in Fastboot mode) to your computer using a USB-C certified data cable.
- If it doesn't work on your computer, try to the following:
- Press simultaneously the keys Ctrl + Alt + T to open the terminal.
- Type
sudo apt-get update
and press the Enter ↩ key.- Type your system password if required.
- Type
sudo apt-get install adb
- Type
sudo apt-get install mtp-tools
- Locate the archive you downloaded in the previous step, (usually in the Downloads folder). Open Chrome Browser.
- Press simultaneously the keys Ctrl + J. A new tab called Downloads will open.
- Look for the last download, the name starts with FP3-.... Click on the writing Show in folder.
A new window will open.
- Extract the archive.
- Using Ubuntu Archive Manager:
- Right-click on the archive, the name starts with FP3-....
- Click on Extract Here to extract the archive.
- Start the terminal and navigate to the folder you just created, the name also starts with FP3-....
- Using the Ubuntu GUI (Graphical User Interface):
- Right-click on the folder.
- Click on Open in Terminal. A new terminal window will open.
- In the terminal window type:
sudo chmod +x flash_fp3.sh
(alternativelysudo chmod +x FP3_FlashAll
) and press the Enter ↩ key. - In the terminal window type:
sudo ./flash_fp3.sh
(alternativelysudo ./FP3_FlashAll
The script will now run for a couple of minutes like in the following picture.
Once done, you will see the following picture.
- IMPORTANT -
It can take up to 15 min. Do NOT interrupt the process, it might damage the device! - Done, your phone is now up to date. Your phone will now reboot, finishing the system update for a few minutes. You can now safely unplug your Fairphone from your computer.
- Once done, for safety reasons, we advise you to lock again your bootloader. To do so, follow the instructions here.
