Use Micro SD card to expand the storage of FP3/FP3+
To expand the storage capacity of your Fairphone 3/Fairphone 3+ (FP3/FP3+) memory, you can use a MicroSD card (dimensions: 15mm×11mm) of all available formats: SD / SDHC or SDXC.
We do not have the capacity to test 3rd party hardware. To have advice on the best Micro SD card to use with your FP3/FP3+, we recommend asking for advice on our forum
More info on Portable storage and Phone storage
You can use a Micro SD card as Portable storage or Phone Storage. The first time you insert an unformatted Micro SD Card into your FP3/FP3+, you will be asked to make a choice. Both options have pro and cons, so take a moment to evaluate them
Portable storage
  • Can be used for media storage only (photos, videos, music)
  • Can be used on multiple devices
  • Can be used to transfer content between devices (ie. a computer, another phone, etc.)
  • Can NOT be used to store apps
  • Is NOT encrypted. If you misplace your micro SD card, you lose your phone or it gets stolen, anyone can see what is saved on it
Phone storage
  • Increases the storage of your device. You will have more space to install apps and games. The software that meets the requirements will be moved to the Micro SD card
  • Is encrypted. You data will be safe if you lose or phone or if it gets stolen
  • Can NOT be used on multiple devices
  • Can NOT be used to transfer content between devices (ie. a computer, another phone, etc.)
  • Can cause data loss in case of breakage or fault
  • Can slow down the performance of your FP3/FP3+. Access the data on the Micro SD Card can be many times slower than accessing the data on the phone
Insert SD card
To insert a Micro SD card into your FP3/FP3+, please, read the instruction below. You can also watch our short video tutorial for more info
  1. Open the back of your phone
  2. Take the battery out. Underneath you'll see three icons outlined in white
    1. On top is the Micro SD card slot
    2. Below are the two nano-SIM card slots
  3. Insert your Micro SD card into the Micro SD card slot
    - IMPORTANT -
    Do NOT force a Micro SD card
    into a SIM card slot. You'll void the warranty!
  4. Press gently all the way in until the Micro SD card clicks in place
  5. Insert the battery again
  6. Put the back cover back on
  7. Press the Power button to restart your phone
Set up your Micro SD card
The Fairphone supports the new format called exFAT format.
After inserting your Micro SD Card and starting your device, a notification icon on the Status bar will show you that an SD card is now installed.
  1. Once you reach your home screen, slide down with one finger from the Status bar to expand the Notification panel
  2. Tap to on the name of your Micro SD card to set it up
  3. A new page will open asking "How will you use your SD card"
  4. Select Phone storage or Portable storage according to your preferences
    Go to the beginning of this article to get more info on both options
- IMPORTANT -
This will wipe all the data currently stored on your Micro SD card
Format your Micro SD card from on first use
You can format your Micro SD card from your phone or from a computer but, before to start using it, for better compatibility, we advise you to first reformat it with your phone
  1. Go to Settings → Storage
  2. Tap on the name of your Micro SD Card (do not click the triangle icon: it will unmount your SD card)
  3. A new panel will pop up from the bottom. Select to open the with Files or Files by Google (they work in the same way), and select also if this should happen Just once or Always depending on your personal preferences
  4. Tap on the More options button (3 vertical dots) in the top right corner
  5. Select Storage Settings
    1. Select Format to use it as Portable storage
      or
    2. Select Format as internal to use it as Phone storage
Convert your existing Micro SD card to Phone storage
If you are already using a Micro SD Card in your FP3/FP3+, as Portable storage it is also possible to convert it to Phone storage
- IMPORTANT -
Be aware that doing so, will wipe all the data currently stored on your Micro SD card
  1. Tap on your Micro SD Card
  2. A new panel will pop up from the bottom. Select to open the with Files or Files by Google (they work in the same way), and select also if this should happen Just once or Always depending on your personal preferences
  3. Tap on the More options button (3 vertical dots) in the top right corner
  4. Select Storage Settings
  5. Select Format as internal
