Safe mode for FP3/FP3+
Sometimes 3rd-party apps can make your device unstable: your device might restart, freeze, crash, or become slower than usual
To identify if a 3rd-party app is causing you issues, you can use Safe Mode: the phone will then restart without loading any external app installed over time
If rebooting into Safe Mode fixes the issue, the problem is probably caused by 3rd-party apps
Please note
- If you suspect misbehavior of a specific app, try to clear the cache of that app first
- Safe Mode will uninstall your widgets. Follow this article to install them again
- You might have to log in to your apps accounts again when you return from Safe Mode. Make sure to save their login and passwords
How to reboot in Safe Mode
If your phone is powered on:
- Press and hold the Power button
- A pop-up opens with the option Power off
- In this pop-up, touch and hold Power off for a few seconds
- You will see a Reboot to safe mode pop-up. Tap OK
- Your device will start in Safe mode. You will see the words Safe mode in a text field at the bottom.
If your phone is powered off:
- Press the Power button until the phone boots
- The animation starts. After the Fairphone logo shows on your screen, press and hold the Volume down button.
Keep holding it until the animation ends and your device starts in Safe Mode - In a text field at the bottom of your screen, you will see the words Safe Mode
Identify problematic apps
The first thing you will notice is that only system apps are active. Any downloaded app is disabled and its icon is greyed out.
Scenario 1: the problem is gone
If the problem does not occur anymore, you have positively confirmed that a third-party app is causing the problem.
You now have to find the app:
- Restart your Fairphone to exit the Safe mode
- Either try to remember what was the last app you installed, or go for your best guess
- Clear the cache of the app
- If the issue continues, uninstall the app and restart the phone
- If the issue persists, another app might be the source. One by one, clear the cache of each app until the issue is gone
- If the issue continues, one by one, uninstall all the recently downloaded apps. After each removal, restart your device in normal mode to see if this solved the issue.
- After you remove the app that is causing the problem, you can reinstall the other removed apps
Scenario 2: the problem persists while in Safe mode
Restart your Fairphone to exit the Safe mode and follow the next two articles
- Make sure the SIM card(s) is not causing the issue
- Try the last resort: perform a Factory Reset
If you are still having issues, get in touch with our Customer Support
