FP4. Take a screenshot
There are several ways to take a screenshot with your Fairphone 4 (FP4). You can take a screenshot via a hardware method or via a software method.
Hardware method
This method works all the time, but you must turn on the screen. To make a screenshot:
- Hold your phone with both hands.
- Press and hold the Volume down button and Power button at the same time. The screen will flash (if your sound is enabled, you'll hear a sound notification).
Software methods (via your touch screen)
This method might be more straightforward, but it does not work for all situations. You can take screenshots of functionalities, apps, or settings, but you cannot take screenshots of notifications, nor the lock screen.
There are two ways to take a screenshot via your touch screen.
First method
- Access the App switcher screen by tapping on the square 🔲 App switcher button at the bottom right of your screen.
- Tap on the Screenshot icon
and text at the bottom of your screen to take the screenshot (if your sound is enabled, you'll hear a sound notification).
Second method
The second method is possible when you have enabled Gesture Navigation (Settings > System > Gestures > System navigation > Gesture navigation):
- Swipe up from the bottom, hold until your open app or functionality reduces in size or becomes visible, then release.
and text that appears on the bottom of your screen to take the screenshot (if your sound is enabled, you'll hear a sound notification).
Access your screenshot(s)
You can access your screenshots in different ways.
Pop-up
After you make the screenshot, you will see a pop-up appear in the bottom left corner of your FP4.
- To share the screenshot, you can tap on Share
to access the Share options and select which app you wish to use.
- You can also tap on Edit
if you need to change or add something. After editing, it saves on your device.
File manager
You can always access your screenshots via your File app, even when the notification disappears from the bottom left corner. To find your screenshot with the File manager:
- Access All apps menu swiping on your screen from bottom to top.
- Look for the Files app, then tap on it.
- Tap the Hamburger button
(three horizontal bars) in the top left corner.
- Tap Images.
- Tap Screenshots.
- Select the screenshot you want to view, share, edit, move, copy, or delete.
- Tap the screenshot once quickly to open and view a single screenshot. This option you can use to share the single screenshot, or view its image information.
- To share: tap the Share icon
on the bottom, and select the app you want to use.
- Tap and hold one screenshot to select it without opening it. You can then pick several screenshots if applicable. You can use this method for all the options.
- To edit or copy: tap the More options button (three vertical dots) in the top right corner for other options (Open with, Copy to or Move to).
on top, and select the app you want to use.
Photos app
You can always access your screenshots via the Google Photos app .
To access the Google Photos app:
- Look for the Photos app
, then tap on it.
- Tap on the Library button in the bottom right corner.
- Under Photos on device, tap Screenshots.
- Choose your action by tapping on the buttons on the bottom menu. You can also use the More options button (three vertical dots) in the top right corner.
If after reading the article you need more help, get in touch with our Customer Support.
