FP4. Maximize battery lifespan
Fairphone 4 (FP4), like most modern smartphones, comes with a lithium-ion battery.
However, unlike most modern smartphones, your Fairphone 4 has a removable battery!
The Fairphone 4 battery holds a typical capacity of 3905 mAh. This should be more than enough to last you through the day. Regardless of how big a battery is, some settings will drain the battery very fast.
Modern lithium batteries are capable of holding the charge for an extended period. Still, the lifespan of your battery is limited. Efficient energy use helps extend the amount of time between charges. You can use the tips listed below to get more out of each battery charge and maximize your battery life.
General
Let us start with some general recommendations.
Always update to the latest software
Software updates often include bug fixes, which let you save energy. We recommend you to follow our article and continually update your Fairphone 4 to the latest Fairphone OS.
Avoid extreme temperatures
Batteries need an optimum temperature to keep the chemical processes inside going. So avoid extreme heat and cold. Do not put your phone in direct sunlight when warm, or close to a radiator. If the temperatures are below zero degrees, keep it inside a pocket when outdoors.
SIM card
Make sure your SIM card is newer than 2 years and undamaged. An old or damaged SIM card makes your phones' processor work harder to keep up and can even cause unexpected issues.
Long storage
If your battery/device is fully discharged for a long time, it may require up to 20 minutes or more of charging before you can notice any difference. Even more, if you have a weak charger. If you do not see any change after a couple of hours, the battery might not work anymore.
If you store your battery/device for an extended period, keep it at room temperature (see above point 1.2 - Avoid extreme temperatures), and make sure to charge your battery between 50% and 80% every couple of months.
A fully discharged battery could fall into an over-discharged state. This will severely diminish its capacity to hold a charge. In the same way, charging a battery that you do not use for a prolonged time, for 100% too often, will also shorten battery life.
Charge regularly
Situations vary, but we recommend to keep the charge of your battery between 80% and 20% at all times to keep it longer. So there is no need to always have it topped off to 100%, but do not wait until 1% is left, either!
Quick charge and fast charge are possible and convenient, but does not extend the lifetime of your battery. Slow charge does. So like taking care of babies: regularity and moderation will last you a longer time!
Optimize your settings
You can use the Quick settings menu to enable or disable some power-consuming features quickly.
The Quick settings menu might have several pages, swipe right to see more icons.
You can also edit the Quick settings menu to add or remove icons. To do so:
- Swipe down twice, with one finger, from the top of the screen. You will open the pull-down Quick settings menu.
- Tap the Pencil icon
in the central left corner.
- Hold and drag the tiles. Bottom to the top to add them to the menu, and top to bottom to remove them.
Display settings
Your screen requires a lot of energy when in use. By adjusting some settings, you can significantly extend your battery life.
Adjust your brightness
Fairphone 4 has an Adaptive brightness feature. It will optimize the brightness of the screen according to your activities and your environment.
- To enable the advanced brightness, go to Settings → Display → and turn on Adaptive brightness.
You can also dim the brightness level of your screen manually. To do so:
- Swipe down, twice, with a finger from the top of the screen. You will open the pull-down Quick settings menu.
- To dim your display, slide the little Sun icon to the left. The A icon next to it is a shortcut to enable or disable the Adaptive brightness.
Adjust your screen timeout
To save energy, you can also shorten your Screen timeout. If you set a Screen lock, a shorter interval will also increase the security of your device if you leave it unattended.
- To adjust the interval, go to Settings → Display → Advanced → Screen Timeout. For a good balance, we advise you to select "30 seconds".
Connection settings
Data connections also use lots of energy. Especially when on the go, it’s advisable to disable the connectivity functions you do not need, such as Wi-Fi when outdoors. If you don't, your phone will constantly seek Wi-Fi networks to connect.
Wi-Fi, Mobile data, Bluetooth
- Tap the desired icon: Wi-Fi
, Mobile data
, or Bluetooth
Be aware that most of the Coronavirus monitoring apps require Bluetooth to be enabled.
Location service
The Location service can also impact your battery usage. When you don't need it, you can disable it using the quick settings menu.
- Tap the Location icon to enable or disable it. You might need to add the shortcut by tapping on the Pencil icon (as we explained previously in this article).
Some apps or services need to know your position to work. Examples are navigation apps, delivery apps, vehicle sharing apps, geotagging apps, etc.
Airplane mode
An effective way to conserve energy without completely turning off your phone is via Airplane mode. If you can spend some time without any connectivity, you use this.
- Tap on the Airplane mode icon
Extras
- If your mobile signal or Wi-Fi is weak, your phone will consume more energy to stay connected. Move where you have a better signal. If you’re not using it, turn off the data connection.
- Your SIM card can cause issues. Make sure it is newer than 2 years and undamaged.
- If you spend lots of time online, you may want to install an ad blocker to reduce the bandwidth and energy required to load a page.
Battery settings
Battery usage
You can see the details of what uses the most energy in your phone. The battery graph shows the pace of energy consumption. Below the graph, the system lists your applications in order of use.
To see the details:
- Go to Settings → Battery → tap the Additional option menu (three vertically aligned dots on the top left corner) → Battery usage to see a graph of your battery usage and the list of the most power-draining apps.
- Tap again on the Additional option menu (three vertically aligned dots on the top left corner to Show full device usage. Now you can see details on which hardware component is using the most energy.
You may see drops in the battery report graph when you first start using your Fairphone. No need for concern: your battery needs to complete a few charging cycles before it calibrates appropriately.
Additional power saving tips
Certain apps, accounts, and features impact your battery life as well. A few ways to decrease your phone’s workload include:
Wallpapers
Choose a static image (instead of a Live Wallpaper). To select a new wallpaper:
- Touch and hold a blank space on your home screen, and then tap Wallpapers at the bottom.
Inactive apps
Close or Uninstall apps you do not use.
- To Close an app:
- Tap the (square) button on your display to show all the active apps. Swipe them up to close them.
- To Uninstall an app:
- Go to Settings → Apps and notifications → tap on SEE ALL APPS → tap on the app you wish to remove → tap on UNINSTALL.
Accounts
You can remove online accounts that you do not use.
- Go to Settings → Accounts → tap on the account you want to remove → tap on REMOVE ACCOUNT.
Users
Remove unnecessary users. You cannot remove the Guest account.
- Go to Settings → System → open Advanced → Multiple users. Tap on the cogwheel icon next to the user profile that you want to remove. Tap Remove user.
Touch vibration (haptic feedback)
Turn off the touch vibration.
- Go to Settings → Sound → Advanced → disable Touch vibration.
Sounds
Turn off additional sounds like dial pad tones, touch, or charging sounds.
- Go to Settings → Sound → open Advanced → disable the function.
Keyboard vibration
Turn off keyboard vibration.
- Go to Settings → System → Language & input → On-screen keyboard → Gboard (the default keyboard) → Preferences → Key press → disable Haptic feedback on keypress.
Battery Saver
To quickly enforce diminished battery use:
- Tap on the Battery Saver icon. You might need to add the shortcut by tapping on the Pencil icon.
When Battery Saver is on:
- The battery icon in the status bar on the top will show an orange outline.
- You might get fewer/slower updates because the apps might update less often. This might also cause the Location services to become less accurate.
If after reading the article you need more help, get in touch with our Customer Support.
