FP4. Global Network Coverage
Europe
Fairphone 4 5G (FP4) is optimized for European cellular networks. It supports Standard 5G technology (also called Sub-6GHz or Everyday 5G).
This technology increases the number of available bands that a device can use to transfer data to the network. Latency is also expected to be improved with 5G when compared to 4G LTE.
Rest of the world
Fairphone 4 5G will work in a lot of countries. However, we cannot guarantee that it will work everywhere in the world. How well the phone works outside of Europe depends on local networks as well as the operator you use.
Fairphone 4 has global coverage for 2G. It works everywhere, all the time, anytime, as long as there's still a 2G network. For 3G and 4G you will get at least one band supported anywhere in the world. This means that it is likely that you will either have a 3G or 4G connection. In some places, it will be the worst-case scenario: a 2G connection. It is possible to set both SIM cards on any combination of connection type, but only one of them can be used for Data connection.
Network coverage across the world is constantly upgrading. We suggest checking the section Network specifications below. Using the list of supported bands, you can verify with your network provider before traveling.
Note that connection to foreign providers can also depend on your provider's contracts and you might not be able to use a network fully, even if the phone has the hardware capability to connect.
Special cases
Some providers restrict international SIM card use - especially on pre-paid plans. Check with your provider what the terms and conditions are for international use.
Colombia, Ecuador, Turkey, Chile & others
It is not possible to register the Fairphone 4 in countries that require the so-called homologar procedure. For example, the phone is not registered in the USA and thus doesn't have the required FCC registration code that would allow usage. The procedure exists to prevent anonymous use of mobile devices. It's used mostly in the North and South American markets.
Registration is mandatory in some countries. This means that you can not use the device with a SIM card after the period has ended that each country has set (usually 1 month). You can still use the device with WiFi or Bluetooth connection.
In short, you can use your Fairphone 4 outside of Europe: make sure that the requirements of your provider and the facilities of the target country/region, match with the network specifications below. You can verify this with your provider.
In case you need it for your specific situation, the network specifications for the Fairphone 4:
- Configuration Dual-SIM, Dual-Standby (DSDS)
- eSIM x 1 - 5G enabled*
- SIM x 1 Nano-SIM (4FF) - 5G enabled*
- Network Technology 2G / 3G HSPA+ / 4G LTE / 5G
- 5G Max Downlink Speed - 2.3 Gbps
- 5G Max Uplink Speed - 200 Mbps
- 5G Supported Bands (Sub 6 NSA bands): n1, n3, n5, n7, n8, n20, n28, n38, n41, n71, n77, n78
- 4G Max Downlink Speed - 1.2 Gbps
- 4G Max Uplink Speed - 150 Mbps
- 4G LTE Supported Bands: 1, 2, 3, 4, 5, 7, 8, 12, 18, 19, 20, 28, 32, 38, 40, 41, 71
- 3G HSPA+ Supported Bands: 1, 2, 4, 5, 8
- 2G Supported Bands (GSM, GPRS, EDGE): 850, 900, 1800, 1900 MHz
* Only one SIM card at a time will be active on the 5G network
If after reading the article you need more help, get in touch with our Customer Support.
