FP4. NFC transmission chip
The Fairphone 4 (FP4) has an NFC (Near-Field Communication) chip inside the Back cover.
NFC is a wireless technology that enables short-range communication between compatible devices. This technology offers several services:
- You can use it to pair Bluetooth devices that support it in an instant. Hold the Back cover of the Fairphone 4 near the device you want to pair.
- Or - thanks to the support of Google Pay - you can turn your Fairphone into a payment device. You pay with your phone! Hold it with its Back cover near the reader of the card machine.
- NFC technology can also communicate with RFID (Radio-Frequency Identification), in combination with applications that can interpret the RFID data. However, without an app to read out the specific data, the NFC can already help identify if an RFID chip is working or not: when a working RFID chip is identified by the NFC by holding it close to the Back cover, it is confirmed by a sound.
Different apps can use the NFC chip to perform various tasks.
Once you install an app that uses the NFC chip, i.e., a banking app, you must enable the NFC on your Fairphone.
To do so, go to Settings → Connected Devices → Connection Preferences → NFC and tap on the toggle on the side to set it to On (the toggle is green when enabled).
- Shortcut Tip -
There is also a faster way to access the NFC settings:
- Swipe down twice, with one finger, from the top of the screen. You will open the pull-down Quick settings menu.
- Tap on the NFC icon
. The Quick settings menu might have several pages; swipe right to see more icons.
You can also edit the Quick settings menu to add or remove icons. For more explanations, you can check the article FP4. Edit Quick Settings menu.
NFC remains active
In case the NFC stays active (the icon remains visible in the top bar), check the following:
- Make sure that you do not keep a banking or other card with an NFC transmitter close to the phone? Then the sensor "always" senses it. For example, a public transport card.
- It can also be that the app you use to read the NFC remains active. In current Android versions, you have to actively deactivate the app (swiping away is not enough):
- Hold the app icon until a text field with "App info" pops up.
- Tap on App info
- Tap Force stop.
- If that doesn't help, check first if your app is not misbehaving.
If you need more help after reading the article, you can use our Troubleshooter or get in touch with our Customer Support.
