FP4. Edit Quick Settings menu
You can use the Quick settings menu to enable or disable some features quickly. The Quick settings menu might have several pages, swipe right to see more icons.
You can also edit the Quick settings menu to add or remove icons. To do so:
  1. Swipe down twice, with one finger, from the top of the screen. You will open the pull-down Quick settings menu.
  2. Tap the Pencil icon Edit_icon.png in the central left corner.
  3. Hold and drag the tiles. Bottom to the top to add them to the menu, and top to bottom to remove them.
If you need more help after reading the article, you can use our Troubleshooter or get in touch with our Customer Support.
