FP4. Back cover and Protective cases
To increase the longevity of your Fairphone 4, we designed extra features to make it as robust as possible. It comes with an integrated back cover.
We do have a Fairphone 4 Protective Soft Case in our accessory line in case you like extra protection for your Fairphone 4.
As with any electronic device, keep it away from sand, dust, and moisture!
Fairphone 4 Back cover
The Fairphone 4 is designed with an integrated Back cover that acts as a battery cover, hosts the NFC antenna, and connects to the core module to contain all the other spare parts. In case you need to replace it, you can find a new one in the Spare parts section of our online shop. For instructions, please watch the first part of our video tutorial:
Sometimes, we are awaiting the arrival of some spare parts. On the product page, you can sign up with your email address to be notified once it arrives in stock.
To remove the back cover, follow the instructions in this video:
Specifications:
- The inside hosts the NFC (Near Field Communication) antenna
Made from 100% (post consumer) recycled plastic: polycarbonate.
Only compatible with Fairphone 4
- Color: Dark grey, Green or Speckled Green
- Length 160.6 mm
- Width 74 mm
- Thickness 3.5 mm
- Weight 15.8 g.
Currently, we are awaiting the arrival of the Fairphone 4 Protective Soft Case grey version. On the linked product page, you can sign up with your email address to be notified once it arrives in stock. We can offer other color versions soon after that.
The Fairphone 4 Protective Soft Case is made from a new line of bio-based thermoplastic polyurethane (TPU), from renewable-sourced materials. It provides the same performance and benefits as regular petroleum-based TPU while reducing it's eco-footprint. Our product team chose this material for its great balance in material properties: the best look and feel, durability against wear & tear, protection of the phone with the highest bio-based content while maintaining a fair price point.
Outstanding benefits of the material are:
- Superior abrasion, impact and puncture resistance
- Antimicrobial
- Fungal resistance
- Very good chemical resistance
- Cold temperature flexibility
- UV resistance
This made it the ideal choice for our protective case, allowing for a slim, lightweight construction, designed for longevity.
Please note: the actual color of the Pastel red Protective Case is Pantone 2032C:
- Material: Non-toxic TPU (plastic) 100% pre-consumer recycled material (so recycled from industry plastics, not plastics of end-users).
- Packaging: FSC certified paper material - Printing ink based on soy
- Colors: Grey, Green or Red
- Grey:
- Pantone: Cool Grey 11c
- CMYK: 0, 0, 0, 79
- RGB: 54, 54, 54
- HEX: #363636
- Green:
- Between Pantone: 5555 and 5545
- CMYK: 43, 0, 34, 38 and 59, 0, 50, 52
- RGB: 90, 158, 104 and 50, 122, 61
- HEX: #5A9E68 and #327A3D
- Pastel red:
- Pantone 2032C
- CMYK: 0, 57, 58, 18
- RGB: 208, 90, 87
- HEX: #d05a57.
- Grey:
- Dimensions:
- Length: 166 mm
- Width: 80mm
- Thickness: 13 mm
- Weight: 30 g
We decided to limit the preparation and coating to diminish the amount of waste and hazardous materials involved in producing the covers, which means that they are more prone to get dirty.
You can easily clean your Protective Soft Case with the kind of cloth used to clean glasses. If you separate it from the phone, you can clean it with baby wipes, a microfibre cloth with soft soap, or address persistent stains with a pencil eraser.
Subscribe to our newsletter to receive product updates.
Please contact our Customer Support team when you have remaining questions or need help.
