Fairphone Chargers
Fairphone devices do not ship with charging equipment.
Since most households have a compatible charger available, this is an effective way to prevent e-waste.
If you do not have the compatible equipment to charge the battery of your device at home, you can buy chargers and cables in our shop.
Only use compatible and undamaged charging equipment to prevent issues and damage to your battery, phone, or worse.
Not sure if your equipment is compatible?
You can verify what the minimum requirements for charging your battery in this article.
In case you have issues with charging - and have ruled out damaged or incompatible equipment - you can use our troubleshooting tool to guide you towards a solution.
Please note that we are closed on 18th April 2025 due to a public holiday in the Netherlands.
Due to a high volume of requests, we have limited our chat opening hours to assist as many customers as possible. If you have an open request, please know we are working hard to get back to you as quickly as we can. Thank you for your patience.
